1993 Dodge Dakota Excessive Fuel Pressure
1993 DODGE DAKOTA
121,000 MILES • V8 • 2WD • MANUAL
CRASHOF2005
  • 7 POSTS
I have an V8 360 out of a 1987 Ramcharger, a 1992 magnum head, a edelbrock rpm air gap intake manifold, and a 600cfm holley carb w/ electric choke...
...ok on with the question
I am having excessive fuel pressure on my truck, which is causing the carburetor to flood when I push on the brakes... I have checked the fuel pressure regulator and it is fine... I have the mallory 4309 with the adjustment screw all the way out pressure is supposed to be 3 psi... It is about 8 psi... so to correct the problem I attached a 1/2" Fuel line to the return line on the regulator and then clamped it onto the metal fuel line under the truck.
My question is when I did that I noticed that the old fuel line was connected to a small metal gas line...This model truck used to be Fuel Injected...Should the Return line be metal because after I did that the fuel pressure did not really change from what it was before...already verified w two gages... If you can think of any other ways to lower fuel pressure, please reply
Thanks for your time
Apr 2, 2008 at 6:21 PM
BLACKOP555
  • 10,386 POSTS
the fuel pump is made to supply high pressure, and maybe you can try to find a low pressure fuel pressure regulator some how, other then that i wouldnt know of anyway to decrease it, you could put a smaller diameter line to get less volume and that might help you.
the return lines are usually metal then the splice into a rubber line.
Apr 2, 2008 at 7:53 PM
CRASHOF2005
  • 7 POSTS
I still have my stock fuel filter on there for the fuel injection I think thats the problem...maybe I need to put a more restrictive fuel filter...after I replaced the clogged one the pressure drastically increased
Does anyone know about what micron filter to get
Apr 2, 2008 at 11:56 PM
