Transmission problem
1992 Dodge Dakota 6 cyl Two Wheel Drive Automatic 308K miles
I recently replaced my water pump. Soon after I noticed a small but persistant transmission fluid leak from somewhere in the engine comparment. I have not had the time to investigate fully. However I realize how important it is to maintain proper transmission fluid levels... so I kept fluid readily available. Last night, Halloween, I had just topped of the transmission fluid and while starting from a red light my truck would not shift into second gear and smoke appeared from the engine compartment. I pulled over and opened the hood to discover transmission fluid all over the passanger side of the engine compartment. Transmission line break/tear/hole? Would this cause the above reaction? Any advice would be appreciated!! Thank you!
Curtis in Colorado
Curtis in Colorado
Nov 1, 2009 at 10:53 AM
