1992 Dodge Dakota shock,spring problem
1992 DODGE DAKOTA
18,000 MILES • 6 CYL • 2WD • MANUAL
GATORCHIN
while removing the left shock, i had the lower control arm jacked up, (brake calipers, spindle, etc were removed for ball joint replacement), i loosened the top nut on the shock the the pressure when it came off caused the spring to come unseated a few inches on the bottom, then the shock was pulled down and is sitting sideways in the spring, the spring is sideways inside the shock..will i have to remove the lower control arm to get all this fixed right??.
Oct 29, 2010 at 7:06 PM
You're lucky you didn't get hurt. You need to get a coil spring compressor, compress the coil and get it back into place.
Be careful. I've see those things shoot across the shop and I know they could have killed someone if they were hit the wrong way.
Nov 1, 2010 at 11:59 AM
First, thanks for the positive feed back. Let me know if you have other questions. Also, you should be able to get the coil spring compressor from a nationally recognized parts store. Most lend them.
Nov 1, 2010 at 8:09 PM
