1992 Dodge Dakota egr system faulty
1992 DODGE DAKOTA
111,120 MILES • 6 CYL • 2WD • AUTOMATIC
GOON132003
ok at fisrt start my rpms idle high and low. after it will stall this happens several times then it will stay on. if i try to keep it running it will gurggle and back fire. when it does run it will drive for a while and start doing the same thing while driving. i did the fault codes and all that came up was 32 which the book says its the egr system.
Aug 27, 2009 at 12:54 AM
For a start clean out the EGR valve, an EGR that's cracked open will cause an erratic idle and stalling.
Aug 27, 2009 at 1:06 AM
