Loose steering
1991 DODGE DAKOTA
70,000 MILES • V8 • 2WD • AUTOMATIC
J HEILMAN
My son-in-laws pickup seems to have very loose steering. It is not that it doesn't respond to the turning of the steering wheel. It is very sensitive to the turning of the steering wheel. I know alot of vehicles have an adjustment set screw on the steering box, but this truck does not possess one
Jun 20, 2010 at 9:34 PM
If your 1991 Dodge Dakota has loose and overly sensitive steering, there are a few potential reasons for this behavior. Here are some factors to consider:
Steering Gear Wear: Over time, the components within the steering gear (steering box) can wear out, leading to excess play and sensitivity in the steering. This wear can cause the steering to feel loose and react more quickly to small steering wheel movements.
Steering Linkages and Joints: The various steering linkages, including tie rod ends, drag link, and ball joints, can wear out or develop play. Loose or worn steering linkages can contribute to both the sensitivity and looseness you're experiencing.
Steering Damper: The steering damper is a shock absorber-like component that helps control steering vibrations and oscillations. If it's worn or malfunctioning, it might not provide proper control over the steering system, contributing to sensitivity.
Tire Issues: Uneven tire wear, incorrect tire pressure, or imbalanced tires can affect the way the vehicle responds to steering inputs. Make sure the tires are properly inflated and balanced.
Alignment Issues: Incorrect wheel alignment can lead to steering problems, including sensitivity and uneven response. A proper alignment can help improve the steering behavior.
Suspension Components: Worn or damaged suspension components, such as control arm bushings or sway bar links, can affect the stability of the steering and contribute to sensitivity.
Jun 23, 2010 at 11:04 PM
