1991 Dodge Dakota engine surges and misfires at highway spe
1991 DODGE DAKOTA
241,000 MILES • V8 • 4WD • AUTOMATIC
BAJA51
have replaced the throtle position sensor no change. it also comes out of o/d and tach goes crazy
Feb 18, 2010 at 12:33 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 18, 2010 at 12:47 PM
