1987 Dodge Dakota Brake Light Troubles???
1987 DODGE DAKOTA
174,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHRIS00626
I have a 87 Dodge Dakota that has a Brake light on and I cant get it off. It is full of brake fluid, the brake pads and shoes are all good. The brakes work good and stop good. It does not have ABS or anything, but the light will not go out. The master cylinder is full of fluid, so any idea??? Thanks
Feb 16, 2008 at 12:06 AM
BMRFIXIT
  • 19,053 POSTS
Check the float inside the master cylinder
what happen it will get stock at the bottom
giving the wrong indication that fluid are low
give the master cylinder a good tap or so
good luck
Feb 17, 2008 at 10:16 AM
