Only runs when plugs out
DODGE COLT
PHISHY75
'89 Dodge colt 1.5L with 200kms. All of a sudden it stopped idling - still ran but would not idle. When slowing down using compression it would blow a puff of blue smoke (abnormal) when I got back on the gas. Got it home and now it wont start.
Here is the kicker... it will run if I remove plugs 2 & 3. Not if I only disconnect the leads, but only if I actually remove the plugs.
Compression is alright at about 120 - 130psi across the board. Got fuel and spark.
Did find some oil in the air filter but the PCV seems fine and the compression checked out.
I'm really stumped here - any help would be MUCH appreciated.
Cheers
Feb 20, 2007 at 12:54 AM
MIKE H R
  • 3,094 POSTS
check the timing. could be a timing belt the smoke could be from a cylinder getting spark at the wrong time.
Feb 20, 2007 at 4:19 PM
PHISHY75
Timing is fine. The belt is only about 6 months old.
Think it might be the Mass Airflow Sensor since it got soaked in oil...?
Anyone know how to pull trouble codes from one of these?
Feb 22, 2007 at 12:12 PM
