1993 Dodge Colt Will not start!!
1993 DODGE COLT
200,000 MILES • 4 CYL • 2WD • MANUAL
HAIRYJMS
We had a bad cold spell back in january.at that time the car would not start,I checked the plugs for spark ( there was no spark) I thought it either be the coil or the ignition module. I was told that the coil is in the distributor and the colis are bad in these models. So I bought a new distributor and installed according to the directions.....Still no Spark!!! oh ya i was told that this model dosen;t come with an ignition module ....is that True? I have had module's conk out before on other vehicles which leaves you stranded with no spark as well. I 've checked all the ignition fuses and they are all good...could it be a ignition relay perhaps....
frustrated
Apr 26, 2008 at 10:38 PM
Do you have power to the coil? also do you hear the fuel pump come On? and power to the black/red wire at the fuel injectors I need to know this to take out the ECM relay- If okay its gonna come down to the ECM.
Apr 27, 2008 at 4:50 AM
