1990 Dodge Colt mikuni fuel injection
1990 DODGE COLT
140,000 MILES • 4 CYL • FWD • MANUAL
JAMES BATES
after driving and car is warmed up engine fails to restart flooded i thinkn will start with gentle push im assuming an engine coolant sensor isnot telling the mikuni injection syetem not to enrich the fuel mixture however i havent been able to find any informtion on the layout or parts i.d. is there a manuel with this information available . or anybody experiencing similar problems thanks for your help
j. bates
Sep 4, 2008 at 5:45 PM
DOCFIXIT
  • 18,828 POSTS
Hi j.bates
The coolant temp sensor is located by the thermostat housing and has a two wire connector. Remove connector you will need an ohm meter check resistance between terminals at 100 F should read 1100 ohms at 180 F 300 ohms if not replace.
On this site you can get repair info at Online Car Repair Manual. Let me if I can help further.
Thank you for your donation
Sep 5, 2008 at 9:25 AM
