2008 Dodge Charger Shifter and temperature/fan lights on co
2008 DODGE CHARGER
36,633 MILES • 6 CYL • 2WD • AUTOMATIC
CHRISJACK
Hello, I just bought a used Charger and noticed that the lights on the shifter and the lights around the fan and temperature knobs are always lit. All of the other lights go off after I shut the car off. Can you please help me? Thank you for your time!!
May 26, 2009 at 10:57 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Do you have a clock, heated seats and cup holder? if yes are the lights on these also?
Let me know
Thanks for donate
May 26, 2009 at 1:09 PM
CHRISJACK
Hello, I do have a clock and cup holder - no heated seats. I took another look and realized that the red triangle for the hazards and the control for the dome/headlights are also lit. Thank you so much! (you're quite welcome for the donate)
May 26, 2009 at 10:48 PM
DOCFIXIT
  • 18,828 POSTS
O.K. Are the lights on in cup holder and clock? Is battery being drained so car won't start? Are the lights effected when dashlight dimmer is turned?
May 27, 2009 at 12:23 PM
CHRISJACK
No, all of the other lights go off - the car starts fine, and the dimmer does not effect the lights. I don't have a light on my cup holder, sorry that I misunderstood!) Thanks again!
May 27, 2009 at 1:41 PM
DOCFIXIT
  • 18,828 POSTS
The lights are controled by a driver circuit in instrument cluster. So a fault in cluster is likely. Does car have warranty? if yes take it in if no will need to be diagnosed with DVOM and pin tests.
May 28, 2009 at 11:57 AM
