Did you hear any unusual noises before this happened? Do you have brake lights? If not check fuses with test light ,also check brake light switch they could cause your shifter safety lock not to function.
Jul 2, 2010 at 1:52 AM
CERTIFIED EXPERT
Or you have a shift interlock control system problem such as the shift control solenoid after brake switch/fuse is rule out
