2006 Dodge Charger Cooling system
2006 DODGE CHARGER
35,051 MILES • V8 • FWD • AUTOMATIC
BOBOLINK51
I need the exact location of the bleed screw for the cooling system. I just changed out the radiator and need to purge the system...
Jan 11, 2008 at 7:45 PM
2CARPRO JACK
  • 11,533 POSTS
there is a plug at the front of the water outlet housing at the front of the engine (may be necessary to install a bleeder valve on 5.7l). Install a hose(4-6 ft long and 1/4 ID clear)and route it away from accessory drive belt and place the end in a clean container.You MUST open the valve before any coolant is added to the engien or it may airpocket.Need to also pinch off the hose that connects the two chambers of the coolant bottle
Jan 12, 2008 at 8:10 AM
