warm on one side cold on the other
DODGE CARAVAN
ANNAFLETCHER
2001 dodge grand caravan, 3.8 , 100,000 miles,
Had a/c recently evac and charged and was working fine then all of a sundden i noticed in the last two days that on the drivers side the air is warmish coolish and the passenger side is ice cold like it should be. Not sure where to start to fix this problem. Thanks Anna
Aug 21, 2007 at 5:31 PM
MISTIDOG
My Caravan just started doing this. Have you had any luck diagnosing it?
Sep 18, 2007 at 9:32 PM
SAWGRASS3
The issue you're experiencing with the air conditioning in your 2001 Dodge Grand Caravan, where one side is blowing warmish cool air while the other side is ice cold, is likely related to a problem with the dual-zone climate control system. Your vehicle is equipped with a dual-zone climate control system, which allows the driver and front passenger to set different temperature preferences.
Here are some potential causes and steps to diagnose the problem:
Temperature Blend Door Actuator: The temperature blend door actuator controls the airflow and temperature of the air coming from the HVAC system. If this actuator is faulty or stuck, it may not adjust the temperature properly, leading to the temperature imbalance you are experiencing.
Blend Door Calibration: Sometimes, the temperature blend doors need to be recalibrated after an HVAC system service or battery disconnect. Check your vehicle's owner's manual for instructions on how to perform a blend door calibration procedure.
Low Refrigerant Charge: If the refrigerant charge in the A/C system is low, it can lead to uneven cooling on the two sides of the vehicle. A refrigerant leak or improper charging could cause this issue.
Faulty HVAC Controls: The control module responsible for managing the dual-zone climate control may have a malfunction or a software issue, causing one side to behave differently from the other.
Broken or Disconnected Air Ducts: There could be a problem with the air ducts or vents, such as a broken duct or disconnected hose, leading to uneven airflow and temperature distribution.
Temperature Sensors: The dual-zone climate control system relies on temperature sensors to monitor the cabin's temperature and adjust the climate settings accordingly. A faulty temperature sensor could cause the system to behave erratically.
Sep 28, 2007 at 8:24 AM
