Greetings,
1996 Dodge Grand Caravan - 200k miles - 3.3L V6.
About 3M miles ago I had a couple of issues that I took care of at once. Front brakes were worn and digging into the rotor, so I replaced both sets of front pads and the driver's side rotor with new ones. Other problem was the front driver's side wheel was bent due to hitting a curb. This resulted in a regular intermittent squeak when the wheel would turn. I replaced that as well.
After replacing the wheel, rotor and brake pads, the intermittent squeaking went away. However soon thereafter (maybe a couple of days?) I noticed when I pressed the brakes it would leap. The problem has gotten progressively worse, until now when we press the brakes the steering wheel shakes and the brake pedal goes up and down a bit. This is more pronounced at higher speeds or going downhill.
I checked the front pads and they are in good shape. Checked for tightness of all the lug nuts - everything tight. I don't know if this an alignment issue or if it is a problem with the rotor or...?
Thanks for any help!
Aug 25, 2007 at 1:42 PM
