2000 Dodge Caravan 3.0 123,000 miles. Runs fine often at start up and for 15 minutes or longer, then starts to run very rough, and engine dies. Eventually, if you keep driving it the Check Engine light will come on, and car may no longer move. But then if you turn it off and wait a number of hours, it will start up and may drive well again for a period of time. But there is no way that I can let my wife and kids use the van, and it is dangerous for me to drive or attempt to drive as well.
Much has been done to attempt to fix it through the reliable garage that always works on my car, but even they have no idea what to do anymore. When the computer is checked, the fault codes that consistently come up are cam and crank shaft sensors. But both have been check and replaced. Also a used computer has been put in, and a new thermostat.
There only idea now is that there is some issue somewhere in the wiriing harness.
Any insights would be greatly appreciated. Thank you for your time and thought given to my problem!
John
John
Oct 5, 2007 at 2:07 PM
