check engine light for dodge caravan SE
DODGE CARAVAN
DODGEOWNER
  • 4 POSTS
hi, is there a way i can get the codes needed for repair when the 'check engine light' turns on without going to the shop? they are asking for $85/hour to run diagnostic test and it seems so expensive.
Mar 19, 2007 at 7:11 PM
SERVICE WRITER
  • 9,123 POSTS
You can get a code reader and we can try to help here. It can get more expensive doing it yourself at times, but we are willing to help. Getting the codes is the tip of the iceberg.
Mar 19, 2007 at 7:23 PM
TDFABER
my local AutoZone store will check it for free..... of course, sometimes you get what you pay for.
Mar 22, 2007 at 10:11 PM
SERVICE WRITER
  • 9,123 POSTS
All you need from them are the codes numbers, take thier " diagnoisis" advice with a grain of salt.
Post your codes, and we'll see what we can do.
Mar 23, 2007 at 4:32 AM
DODGEOWNER
  • 4 POSTS
hi, i went to autozone and they gave me a free reading. thanks a lot for the help...here's the code i got, its P0465
Mar 26, 2007 at 6:30 PM
SERVICE WRITER
  • 9,123 POSTS
What year and motor size?
Mar 27, 2007 at 4:55 AM
DODGEOWNER
  • 4 POSTS
its a dodge caravan 2003 SE. 3.3L V6 engine. i made a mistake on the code...its P0456 instead.
Mar 27, 2007 at 9:35 PM
SERVICE WRITER
  • 9,123 POSTS
IT is a medium leak in the evaporative system. This may be a loose gas cap or a gas cap seal that is bad. However it may not be that simple and may require the system to be tested. There is a tsb about this that related to replacing the pcm.
Mar 28, 2007 at 5:29 AM
DODGEOWNER
  • 4 POSTS
this will mean that i need to go to the dealership to have this serviced? is there a way to do this by myself?
Mar 29, 2007 at 5:36 PM
SERVICE WRITER
  • 9,123 POSTS
I am inclined to recommend taking it to an independent shop that is up to speed on diagnosing. I may be able to locate one in your area, or help you to. A shop is only as good as the staff-that includes dealers. There are some good bad and ugly in all of the industry.
If you replaced the gas cap, and put the tank at 3/4 full. Then drive normally for a few days, that MAY solve it. This isn't a problem that is going to need immediate attention.
What will be tough for you to go after it yourself it may be the tools of the trade, such as possibly a smoke machine ( a machine that injects smoke into the evap system and exposes leaks, or if there is a faulty computer ( which may come down to a guess) or a scanner that can operate the system. NOt to mention the knowlege of the system.
I'll help where I can, as you like. Ask away and I'll try :)
Mar 29, 2007 at 5:56 PM
C.HERRERA
  • 8 POSTS
You can check your own codes in your own van key in ignition your going to turn the only to the on position that turns on your lights ...not all the way on ..on off on off on (kinda fast) wait a sec and the code or codes will show where your mileage shows when it is done with your codes it will say done ..this only works on dodge
Jul 27, 2017 at 7:01 PM
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Jul 28, 2017 at 4:47 PM
