Check engine codes
DODGE CARAVAN
TONYSAPP
I have a 2001 Dodge grand caravan that wnet into Limp mode. The three codes that came up are P0401, P0605 and P0700. Does anybody know what the normal fix is for these codes?
Jun 16, 2006 at 10:18 AM
CALIBER51
  • 5 POSTS
You mentioned the code numbers that came up, but you didn't say if you knew what they meant. So here it is:
PO410=exhaust gas recirculation flow insuffient detected
PO605=internal control module read only memory error
PO700=transmission control system malfunction.
I don't know if this helps or not, but good luck.
Sep 16, 2008 at 12:51 PM
