2007 Dodge Caravan hOWLING NOISE FROM FRONT WHEN BRAKING HA
2007 DODGE CARAVAN
37,000 MILES • 6 CYL • FWD • AUTOMATIC
ADDIS3363
Would like to know what possibly might be causing a loud roar when braking hard. During normal braking there is no noise. The brake rotors have no grooves and the car has good functional braking.
Dec 14, 2009 at 10:38 PM
It could be a few things. First, are the tires worn evenly and not cupped or chopped? Also, if you turn when hitting the brakes, does the sound change?
Dec 15, 2009 at 8:52 PM
ADDIS3363
The answer is no to all of your questons. The noise sounds like a low pressure snow tire going flat. It wouldn't surprise me that it has something to do with a front wheelbearing. The only question is why doesn't the noise change when in a turn?
Good Luck,
Peter
Dec 16, 2009 at 10:43 AM
I agree. Wheel bearings will usually change when you turn. However, they can be constant.
Dec 16, 2009 at 1:15 PM
ADDIS3363
Do you have any trubleshooting procedures to give me in order to define where the problem is and if I elect to not repair is there any chance there could be some unsafe condition that could result?
Regards,
Peter
Dec 16, 2009 at 7:40 PM
Safely lift the front of the car and check for side to side play or up and down play in the front wheels. Let me know what you find.
Dec 16, 2009 at 8:13 PM
