Ignition coil secondary circuit A,B,&C malfunction.
Should I replace the coil pack.
Nov 12, 2008 at 9:19 AM
CERTIFIED EXPERT
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
