The 2005 caravan has the factory (dealer) provided remote starter.
Lately using the remote starter, the engine turns, fires, starts and shuts off after 1-2 seconds.
Manual ignition key start never has any problems.
This behaviour was intermittent, now it is permanent for the last month.
Under the hood, the remote starter fuse to the battery is good and clean. In the fuse box I see one wire going to the flasher relay, that works fine with good contact. I cleaned out all the relays and fuses but no change.
The hood switch works fine.
Having a bit of experience with remote starters, I think there is a wire to read RPM. I was wondering if that might be faulty, as if the remote starter box does not see the engine turning so shuts off ignition.
But, where would that be connected? Dash? Under hood? I do not know where to look.
Thanks in advance for any comments.
Dec 17, 2019 at 2:40 PM
(Merged)
