2005 Dodge Caravan P0406
2005 DODGE CARAVAN
74,000 MILES • 6 CYL • FWD • AUTOMATIC
ONERADOK
  • 18 POSTS
This is the second time on a long trip that this van had the P0406 code when the van stopped after 8 hours of travel. The Check engine light went out the next day, and never came back on during the return trip. Any idea what might be causing this?
Jun 27, 2009 at 11:49 AM
MERLIN2021
  • 17,250 POSTS
Symptom: P0406 - EGR POSITION SENSOR HIGH When Monitored and Set Condition: P0406 - EGR POSITION SENSOR HIGH When Monitored: With the ignition on. Battery voltage greater than 10 volts. Set Condition: EGR position sensor signal is greater than 4.89. One trip Fault. POSSIBLE CAUSES  EGR POSITION SENSOR SIGNAL CIRCUIT OPEN  EGR POSITION SENSOR SWEEP  INTERMITTENT CONDITION  EGR POSITION SENSOR SIGNAL CIRCUIT SHORTED TO 5 VOLT SUPPLY CIRCUIT  EGR POSITION SENSOR SIGNAL CIRCUIT SHORTED TO BATTERY VOLTAGE  EGR SOLENOID ASSEMBLY INTERNAL FAILURE  SENSOR GROUND CIRCUIT OPEN  PCM
https://www.2carpros.com/forum/automotive_pictures/62217_caravan33_copy_1.jpg
Jun 28, 2009 at 6:20 AM
ONERADOK
  • 18 POSTS
Ended up changing the EGR valve, along with the belt since I had to loosen the alternator to get that lower bolt out. It was still in decent shape, but figured it was probably a good time to do that too.
Thanks again for the help.
Jul 2, 2009 at 8:26 AM
MERLIN2021
  • 17,250 POSTS
Thanks for the plug!
Jul 3, 2009 at 4:14 PM
