2005 Dodge Caravan ABS Light
2005 DODGE CARAVAN
TIGGI915
Brakes problem
2005 Dodge Caravan Engine Size unknown Wheel Drive Type unknown Automatic 45,000 miles
The ABS light came on in our van about a few months ago and hasnt gone away. We haven't had any issues with the brakes. But i would like to get the problem taken care of. I called the dealership to see how much it would cost to fix and they want $100.00 just to see what the problem is. Well, we don't have 100.00 to toss out there, unless its to fix the problem. Anyway, i was wondering if there is anything we can do to fix it, instead of taking it in somewhere. My husband would really like to fix it himself if he can.
Feb 20, 2008 at 2:09 PM
BMRFIXIT
  • 19,053 POSTS
With out the scanner you cant go far
check local repair shop for help and get some estimates
once you have the code s you can change repair the problem
all he can do for know with out the scanner or codes is
check brake fluid check wires at the tire sensors check fuses
good luck
if you get the codes you may post them for more help
good luck
Feb 20, 2008 at 2:27 PM
TIGGI915
[quote:8e6889d41d="BMRFIXIT"]With out the scanner you cant go far
good luck
good luck[/quote:8e6889d41d]
Thanks! I'll pass this info on to my husband =)
Feb 20, 2008 at 3:12 PM
