blower motor not working?
2004 DODGE CARAVAN
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
WALTERMCGRAW
blower motor does not work for heat or air?
Oct 20, 2008 at 12:11 PM
Hi:
The blower motor not working can be caused by several things. To start, I would go to the blower motor resistor and check for power. The resistor is on the firewall. If there is power there, you will need to get to the motor itself to check for power. It's located under the dashboard. If power is to the motor and it doesn't run, it will need replaced.
This guide shows you how
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Let me know what you find.
Oct 22, 2008 at 8:50 AM
THOMAS M. NIEHUS
The fan blower for the front passengers quit working. The air works as well as the blower for the rear passengers.Where can I find a print for fuses?
Could it be an overload reset for the blower motor?
How big a job is it to change a blower motor if need be? Thanks. Tom
Nov 3, 2020 at 9:12 AM (Merged)
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_blower_motor_2.jpg
Hello, I came across the above info, hope it is readable.
QUAD GOD
i was wondering how to go about replacing the front blower motor.what all has to come apart?i can see the motor bolts in from underneath,but i am unsure about the cover underneath.
i am a ford senior master certified technician,but i do not work on dodge vehicles very often,and i dont want to do more work than necessary.
thank you for your time, dan
BMRFIXIT
  • 19,053 POSTS
[quote:5364adf9f6="quad god"]Heater problem
2004 Dodge Caravan 6 cyl Front Wheel Drive Automatic 81976 miles
thank you for your time, dan[/quote:5364adf9f6]
straight forward the way you see it
remove cover remove bolts remove motor
Ps did you check the relay under the hood ?
JOEHOKIN
  • 4 POSTS
intermintinally not working rear blower works fine ,have tried swappiing blower relays . no luck. any ideas?
When it stops, does it work on any speed? Have you checked the motor to make sure the wires are tightly connected?
JOEHOKIN
  • 4 POSTS
no, and yes i have checked conn @ plugs behind the glove box. does mtr have internal overload that resets automatically?
If it doesn't work on all speeds, is it only the high speed that it works on?
JOEHOKIN
  • 4 POSTS
no
Can you describe what it does?
JOEHOKIN
  • 4 POSTS
it will work on all speeds for hours sometimes days,then it won't . normally after the car is turned off,and sometimes while driving along it stars working again.
It sounds like you either have a bad blower motor relay or a loose, corroded connection to the fan motor, or a bad ground.
Have you checked any of the items I mentioned?
CHRISTIANRUMENAPP
"I am having electrical problems - no gauges , no wipers , cannot turn headlights off , cannot turn heater blower motor off , no aux key position , sometimes transmission will not shift to higher gear, couple other minor things. Any idea what it may be?"
first, have battery and alternator checked for proper operation, an alternator putting out ac voltage will confuse the pcm and make it do stupid dtuff.
have the bcm checked for codes as it is the common denominator for all these functions
CHRISTIANRUMENAPP
Thanks - What is the pcm and the bcm?
pcm is the engine computer and bcm is the body control module which all body functions go through
CHRISTIANRUMENAPP
Thanks a lot!!
good luck
roy
MARK DUNSMORE
the 2 medium setings on blower for air conditioning or heater does not work...the low and high settings do work...is just a fuse?
Nov 3, 2020 at 9:14 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
[quote:0df8f959bc="mark dunsmore"]Air Conditioning problem
2003 Dodge Caravan 6 cyl Front Wheel Drive Automatic 86000 miles
the 2 medium setings on blower for air conditioning or heater does not work...the low and high settings do work...is just a fuse?[/quote:0df8f959bc]
no its a blower moter resister
on right side of the hvac
