2004 Dodge Caravan ABS problems
2004 DODGE CARAVAN
102,000 MILES • 6 CYL • FWD • AUTOMATIC
MARCUS_01
I have a 2004 Dodge Grand caravan SXT. Recently my ABS light on the dash has come and stayed on. I also lost the traction control due to the light being on. Last time this happened, it was a frozen sensor. So this time I've parked inside for a couple of days, removed the wheels and sprayed hot water to melt the snow and ice. After all was done I removed the battery to reset the computer. Still today the light is on, with no ABS or traction control. What else could it be??
Thanks,
Jay
Feb 3, 2008 at 9:10 AM
BMRFIXIT
  • 19,053 POSTS
[quote:8cb0e4dd9e="marcus_01"]Brakes problem
2004 Dodge Caravan 6 cyl Front Wheel Drive Automatic 102000 miles
Thanks,
Jay[/quote:8cb0e4dd9e]
With ABS system you need to have system scanned
you can check brake fluid and brake light switch
codes will point you in the right direction
Feb 3, 2008 at 7:18 PM
