Grand Caravan heat was not working and temperature would go to red then drop.
- I replaced the thermostat.
Heat now works and temperature stays below half way mark. From this it seems water pump is working properly.
However - Radiator is steaming on inside side, radiator is low on fluid..
Twin fans are not coming on.
Seems radiator overflow is directed down edge or front of radiator. I can't follow it under cowl.
-> It seems radiator is not being cooled so, water/anti-freeze is boiling out overflow hose.
I switched windows fuse with Rad Fan fuse. Windows still work but, fans still don't come on.
- Fan fuse must be ok.
How can I test the fans? Do they have in line fuses?
Thank you,
Backyard Bobby
Thank you,
Backyard Bobby
Feb 2, 2010 at 2:13 PM
