Engine will not turnover
2003 DODGE CARAVAN
JERRY 9947
  • 4 POSTS
Six cylinder front wheel drive automatic 98,000 miles.
Battery good, ignition good, starter good, all fuses and relays good. if I jump the starter relay contacts the engine cranks, but still will not start. After further checking I do not have a ground path to starter relay fuel pump relay and coil packs I think it may be computer. the Haynes book says the PCM module could cause this problem and states the module is located behind the driver side bumper the module there is for transmission so where do I go from here? I know electronics radio and TV repair for thirty years and thirty five years at Lockheed Martin Space Shuttle Electronics, but I do not have much Dodge back ground. I drive a Chevrolet truck because it is dependable. Wife likes her Caravan good when running not too good right now. Thanks, Jerry
Feb 3, 2009 at 5:29 PM
Is the security light flashing? if so I would try resetting the security system here is a guide.
https://www.2carpros.com/articles/how-to-reset-a-security-system
If not I would check the neutral safety switch or starter relay. Here are guides and diagrams to help.
https://www.2carpros.com/articles/how-a-neutral-safety-switch-works
and
Check out the diagrams (Below). Please let us know what you find.
Cheers
Feb 4, 2009 at 4:03 AM
JERRY 9947
  • 4 POSTS
It does not have grounds to the relay coils to latch relay contacts that was my guess that the computer went out. thanks, I did not have a schematic of the computer but using logic that is what I came up with! the other part of the question was which one was it? another site tells me in my van there are two computers, one behind the driver headlight and one behind the driver side bumper. my guess it is the one behind the head light. Thanks, Jerry
Feb 4, 2009 at 5:47 AM
Below is for the transmission control module the main computer for both the transmission/engine so you can see the location (below)
Feb 4, 2009 at 2:07 PM
JERRY 9947
  • 4 POSTS
my van has two modules I took both out 1) one was behind the bumper on the driver side. 2) the other was in front of the battery on the driver side. Your diagram is for an inline six cylinder engine this one is a trans-axle side ways engine. I have the part numbers for both modules. the one in front of battery is #472521aab the one behind the bumper is 4727721ae. I know of no Caravan with a straight inline engine. I took both modules to Autozone who advertises they check modules, but they do not do it!
Feb 4, 2009 at 3:14 PM
It is not an inline engine it is a 3.3L/3.8 Transverse engine.
https://www.2carpros.com/forum/automotive_pictures/12900_transverse_engine_1.jpg
Feb 4, 2009 at 4:13 PM
JERRY 9947
  • 4 POSTS
Sorry you are right v6 not straight six. too many cars here to keep up with but only one Dodge. I got the right module location it was the one in front of the battery not the one behind the bumper that's the transmission module Haynes manual was incorrect as to where the PCM module is. However, the Dodge dealer said there were two different late and early starting 2003 the early model used one module and later went to two modules. thanks for all your help! this was a learning experience for everyone involved. I will order module from internet tonight $199.00 with lifetime warranty in stock and includes shipping. Dealer did not have it ten to fifteen working days to get it. No brainer the net has it and I will have it in three days not weeks. I will post to let you know if that cures the problem I think together we agree it has to be the module. Jerry
Updated 3/5/09
It was the PCM module. I replaced it with the $199.00 from the web came pre-programmed ready to plug in. that is what I did. cured all problems plug and
play the code reader did not show a code or fault that was what I could not
understand. but all the electrical checks pointed to the PCM module so I went
with logic; replaced the PCM module it will fix it! removed the two bolts
from top bracket and the three bolts that hold the headlight assembly and
remove headlight assembly for access to the one bottom bolt for the module
unplug the two cables replace module and reinstall every thing in reverse.
It is a done deal in fifteen minutes in the dark. Jerry
Feb 4, 2009 at 5:25 PM
KENNYKBE
Jerry,
I had this problem as well I replaced the starter relay and everything worked great! Thanks for the guides.
Thanks, Ken
Mar 4, 2009 at 7:24 PM
I have a 3.3 liter engine it has 180,000 miles. it went off on me running it starter jerking on me running it went off and then i started again and it ran for two miles and then it went off again. today i turned it on and it ran for five minutes then it went off again. now it will not crank up. the engine is working, but the lights and etc., work but i cannot turn the engine on. i installed a new battery and alternator. the starter has power but it will not turn on. can you tell me what is wrong with it?
May 4, 2017 at 4:53 PM (Merged)
Could be ignition switch or neutral safety switch.
Beyond that, it sounds like you have another issue. start with a fuel pressure test, compression and spark.
ED ATKINS
Six cylinder front wheel drive automatic 52,000 miles.
Parked in garage working fine, would not crank next morning. Battery okay, ignition sending power to relay. will crank if jump relay, but will not star.t check engine light not on. with key will not cycle. battery drained out after setting a day.
Does the vehicle have a factory alarm/security system? Also, have you checked to see if there is a draw on the battery or if it is just bad? Here is a how to for checking for a draw:
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
SHELLBELL33
Six cylinder two wheel drive automatic.
When i turn the key to start it all the lights come on, but it will not start. there is no clicking noise or any noise at all. the battery is good and the starter is good. but it will start sometimes. then sometimes it will not. It does not start more than it does start. do you have any suggestions on where to start troubleshooting first?
No crank at all/nothing.
Could be a blown fusible link the starter, starter relay, clutch switch/park and neutral switch/transmission position switch and ignition switch, assuming the battery and connections are good.
JAMESCS
  • 4 POSTS
Six cylinder front wheel drive automatic 100,200 miles.
my van now has a new starter attempting to solve this problem, but the problem remains. it still will not turnover at all sometimes, usually it will start cold but once warm and shut off for an hour or so it will not turnover.
the last time it sat for three days never once turning over, then suddenly it started up and runs fine.
i switched out a relay under the hood still the same thing.
once it starts it runs fine for hours until you shut it off then it often will not turnover at times again.
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will have to check for power at the starter solenoid when it will not start, and if okay you may have a faulty new starter. If no power check back down the line to relay and relay power supply. check battery terminals are clean and tight, and all earths are okay. Start here.
Mark (mhpautos)
JAMESCS
  • 4 POSTS
i measured the the volts at the big cable on the solenoid (not the plug in cable), it shows 26 volts without turning the ignition switch.
i replaced out two of the relays that pertain to the starter, still the same result.
do i need ot measure the plug in wire to the solenoid?
it is hard to get a reading on it.
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will need to make sure you are getting voltage at the solenoid wire when key on crank. if okay starter will be faulty.
Mark (mhpautos)
JAMESCS
  • 4 POSTS
Drats, i measured AC instead of DC voltage!
okay i will measure the other wire. i need to make a small cut in the insulation to get my test probe on it.
thanks for the reply, i will get back tomorrow with results.
JAMESCS
  • 4 POSTS
no power to the solenoid is showing with the key switched to start.
i have swapped out the relays. should i check ignition switch next?
none of the grounds appear to be corroded anywhere.
  • 0 POST
It just quit. will not crank by key. fuel pump not kicking on. what could be problem?
May 4, 2017 at 4:54 PM (Merged)
Make sure all main fuses in the power distribution box under the hood are good. If they are and nothing works with the key, chances are the ignition switch is bad.
SMURFETTE92602
Six cylinder all wheel drive automatic 90,000 miles.
My husband and I have been driving this van for over two years with no issues and recently just drove it over 1,000 miles with no problem. I went to leave my office at the end of the day a week later and the van would not turn over. Lights, radio, etc., all good. Called for service and jumping the van failed. Took it to the garage, repair guys charged me $80.00 for diagnostics and investigation. They believed to be a loose wire to the computer. Could not find it and the fees were adding up. :-( We suspected the starter but the garage would not replace it. We waited until the van would start again, paid the fees, drove it home and parked it in our driveway. Within the last two weeks we were able to start it (did not drive it) three times out of maybe fifteen attempts. Twice in a row one day and later that morning it did not start. Tried another day around lunchtime thinking maybe cooler temperature outside and the van started in about eighty five to ninety degree weather. At this point we do not know what to do. Can someone offer some suggestions? We did not hear anything else besides the computer or loose wire. My parents had a similar issue with their 1996 Dodge Caravan and actually had to rock the van to start it, does not work for me. :-) They replaced their starter and fixed their issue so they figured there was a short in their starter or some failure. Any advice would be greatly appreciated.
Thank you,
Smurfette
BMRFIXIT
  • 19,053 POSTS
Try to move the shifter to neutral and then start.
check the small wire at the starter it should have power when key in start position
big wire at the starter should have power at all times. check and or mark the relays and switch them around. disconnect the battery clean terminals and connectors and re-tighten.
Replace starter.
