Engine problem
2003 Dodge Caravan 90000 miles
My coolant level keeps going down and I am pretty sure that I am losing coolant from the gasket by my water pump. Do I need to do anything special to replace the water pump on a 2003 Grand Caravan or is it straightforward? I read one comment about someone not having clearance to remove the pulley and pump and I don't want to get stuck in that situation.
Also, on a different note, when I hit the recirculation button for the cabin heater the light on the button flashes and then goes out, so the recirculation is not working. What does that mean?
One more, if the turn signal does not turn off for left hand turns only, where is the problem?
Thanks.
Thanks.
Jan 7, 2008 at 8:51 PM
