2003 Dodge Caravan 2003 Caravan Jerks
2003 DODGE CARAVAN
94,000 MILES • 6 CYL • FWD • AUTOMATIC
RONHANOUDI
Hi, I have a 2003 Dodge Caravan with 3.8L engine. Recently the vehiicle shook on highway while some noise was coming from the muffler (rear right of car). This lasted for about 20 seconds and the car sounded like it was going to stall.
The car did not stall, and I continued driving for an hour after the incident with no issues. I however did not dare driving over 65MPG as I was not sure if thats what caused the issue. Again, this issue happened 3 days ago and the symptom did not appear again.
Any idea what could have caused this and will it come back again?
Dec 19, 2009 at 7:19 AM
MHPAUTOS
  • 31,937 POSTS
HI there, not all that sure what this can be, is the exhaust in good working order? check that you don't have a muffler collapsing and causing a problem, also just to be on the safe side get a scan done to check for any unresolved fault codes, start here.
Mark (mhpautos)
Dec 19, 2009 at 7:39 AM
RONHANOUDI
[quote:253d0368da="mhpautos"]HI there, not all that sure what this can be, is the exhaust in good working order? check that you don't have a muffler collapsing and causing a problem, also just to be on the safe side get a scan done to check for any unresolved fault codes, start here.
Mark (mhpautos)[/quote:253d0368da]
Thanks Mark. The muffler might be the cause here...I will have it replaced. In cold weather mufflers do tend to rust at about 100K. Also, you are right...there is a check engine light thats on. I will make sure to take care of it.
Dec 19, 2009 at 7:56 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
If you get tuck with the codes, post them here for more assistance.
mark (mhpautos)
Dec 19, 2009 at 8:20 AM
RONHANOUDI
I forgot to mention the car was in cruise control when the issue occured. A mechanic asked me that question and he thinks the cruise control is not correctly working and the jerking noise was that similar to when the car runs out of gas.
He could not find anything else wrong with the car.
Thanks....
Dec 28, 2009 at 7:29 AM
MHPAUTOS
  • 31,937 POSTS
Did you get a the codes checked? if it was in cruise, it may be a speed sensor acting up.
mark (mhpautos)
Dec 28, 2009 at 8:46 AM
