2002 Dodge Caravan voltage regulator IN PCM
2002 DODGE CARAVAN
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
BECCA_WRIGHT
I have found information that the voltage regulator in the PCM can be tested seperate from replacing the whole unit, cant find WHERE that is exactly. we have tried just about everything, fuel pump, sensors, new MAP, and it is still not starting and throwing the same codes. At a total loss on this one. Fuel pump engages repeatedly and getting no fuel, stalls while driving when it does start. Runs like a champ then dies when it does start,,,any thoughts????
codes
645
134
108
320
1389
1391
there were only the O2 sensor and high volt to Map before we changed the map
Sep 19, 2010 at 11:50 AM
When you say the fuel pump engages repeatidly, do you mean it is on off on off... When it doesn't start, are you getting spark and fuel to the engine?
As far as the regulator, that will cause the battery to go dead. Is that happening?
The fuel pump regulator is on the fuel rail. I need you to check if you are getting constant fuel pressure within specs.
Let me know what you find and if you replaced the fuel pump relay.
Sep 20, 2010 at 3:01 PM
