Turn Signal Flasher Location
2002 DODGE CARAVAN
KENNS
  • 4 POSTS
Electrical problem 6 cyl Two Wheel Drive Automatic 60,000 miles
Where is turn signal flasher location on my 2002 Caravan Sport? Are there any photos of what it looks like. They tell me it's under the dash by the steering column, but I cannot locate. -KS
Apr 6, 2010 at 8:02 AM
CH112063
  • 1,320 POSTS
You won't find a flasher like your used to. All the fuses are in the front power center called an intelligent integrated control module, the combination(turn signal switch) only signals the body control module (BCM). It operates the lamps on the dash and it relays the front module, this controls the relays behind the quarter panel trim. Actually it's a little better than 2001. Test the fuses. What is wrong? Are any bulbs out?
Here are the blinker wiring diagrams so you can see how the system works.
Cheers
Apr 6, 2010 at 9:16 PM
KENNS
  • 4 POSTS
the blinker are just not working they don't even come on.
Apr 7, 2010 at 5:54 AM
CH112063
  • 1,320 POSTS
Use this guide to test for power inputs and outputs of the TIPM
Sorry I should have said that in the first post :)
Apr 8, 2010 at 8:22 PM
KENNS
  • 4 POSTS
All I have to do is identify the pin on each input I will need to get some time to do that I will report back
-KS
Apr 9, 2010 at 5:22 AM
CH112063
  • 1,320 POSTS
Check the BCM is connector can get burned out bulb from taking a dump.
Any lights on that side out beside the blinkers? If you need the tracer colors for each wire here is another guide I found
Apr 10, 2010 at 6:27 PM
KENNS
  • 4 POSTS
Seems like a pain in the butt just to change a stinking turn signal flasher. I'm old school and it used to be a simple matter to change one, so I ended up replacing the TIPM and now everything works ya!
Thanks for your help on this one.
-KS
Apr 11, 2010 at 6:44 AM
CH112063
  • 1,320 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers
Apr 11, 2010 at 7:32 PM
