EZ struts very much the same as described in the 1st few steps
As they come complete and no need for any special tools
Just remove old struts assemble and install the new one ,strut coil spring and all in one
Easy and way to go for a to do home job
i would replace stabilizer link too.
Good luck
Raise and support vehicle.
Remove wheel.
Remove brake hose and speed sensor brackets. Remove stabilizer link.
Remove cam adjusting bolt and steering knuckle bolt from strut damper assembly.
Remove strut damper-to-shock tower mounting nuts.
Remove strut damper assembly from vehicle.
Apr 23, 2010 at 6:54 AM
