2002 Dodge Caravan removal of interior door panel
2002 DODGE CARAVAN
97,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVE GADD
The sliding door on the passenger side will not unlock and open. How do I take the interior door panel off so I can check for the problem. All other doors unlock using the remote and the switch on the front doors.
Jan 11, 2010 at 4:34 PM
CH112063
  • 1,320 POSTS
You must remove the upper molding first, there are screws and push pins that hold it on, one is hidden where the ash tray is, and one on the lower right, then pry it out use a trim removal stick or a rag and a screwdriver tyo keep from scratching the paint, if the handle bezel won't come off, you need to lift and pry it back gently, it holds the trim in place also, on a non-motorixed door. hope this helps, once one clip pops out you'll see and feel exactly where the hold downs are.
Jan 11, 2010 at 9:01 PM
