Brakes problem
2002 Dodge Caravan 6 cyl Front Wheel Drive Automatic 147k miles
the rear wheels are locked on driver side i removed tire, rotor pads, emergency brake cables. the rotor will not come off. in the adjustment port there is a spring where the adjuster should be. i have also clipped the pins holding the emergency shoes. the rotor will not come off. the wheel mounting will move about 1/4 inch but stops hard like a mechanical stop not shoe pressure. im looking at breaking the spring and see if that releases the shoes so rotor will come off. any suggestions are appreciated
thanx for your site
Maru12
thanx for your site
Maru12
Aug 6, 2010 at 11:23 AM
