2002 Dodge Caravan Rear Brake/Headlights/Parking Lights Sta
2002 DODGE CARAVAN
108,000 MILES • 6 CYL • 2WD • AUTOMATIC
TIMX416
Hi -
I noticed the rear lights (brake, headlights, parking lights) stayed on after I turned off the vehicle and removed the key.
I tapped on the brakes to ensure the brake pad was not "sticking" causing the rear brake lights to be on.
I think turned the headlights on / off with and then without the engine turned on.
I turned key to accessory, then off then this then that.
The only thing that stopped the lights from remaining on was removing the Stop Lamp Fuse (20a) from the fuse control center. This was the only way to stop the lights from remaining on.
I'm a little versed in home electric - and know this probably isn't a good situation - but, we only need to drive this car in Daytime.
I'd like to fix myself...and it seems that there is either a short, a faulty relay etc.
Thoughts - Ideas - Etc? I know taking to a mechanic would be an easy fix....I just lost my job Monday and have a new affinity for fixing things myself. I have been changing my oil for years (and I'm a white collar worker) - nothing like getting your hands a little dirty.
Thanks in advance - any insights on fixes would be appreciated.
TimX416
May 19, 2009 at 12:30 PM
DOCFIXIT
  • 18,828 POSTS
Hi
On left side engine compartmentnear headlight fine Integerated Control Module. In it is the Front Control Moudle that is faulty. Controls everything that is staying on.
Hope this helps
Thanks for donate
May 19, 2009 at 2:35 PM
TIMX416
I've been out to about 30 websites and there are quite a few "control" modules. Can you at least give me a part number or what specifically to call the part? Is it a "Stop Lamp Integrated Control Module"?
What is your expectations on how much the part will cost (part only - no install)? It seems to be a quick fix....correct? or do i have to take apart half the engine.
May 20, 2009 at 2:52 PM
DOCFIXIT
  • 18,828 POSTS
It is inside the Integrated Control Module on left side engine compartment in a black box. Front module is there. I have no part no. need to call dealer and give Vin number.
May 21, 2009 at 9:46 AM
