2002 Dodge Caravan popping and grinding when turning or at
2002 DODGE CARAVAN
103,737 MILES • 6 CYL • FWD • AUTOMATIC
TONY102090
When I turn I can hear a popping and grinding noise from the front end and sometimes going down the road at a low speed.When I drive at a speed above 50 mph I don't hear the sound at all. The mechanic says everything is tight and sees nothing wrong. What could it be?
Aug 27, 2010 at 7:28 AM
DOCFIXIT
  • 18,828 POSTS
Check CV joints
Aug 27, 2010 at 10:27 AM
TONY102090
I was told by a mechanic that the cv joints are fine.Someone told me that it may be the sway arm bushings.Is this possible?
Aug 28, 2010 at 3:30 PM
DOCFIXIT
  • 18,828 POSTS
Could be also lower control arm bushings. Hear it more on a left or right turn?
Aug 28, 2010 at 3:36 PM
TONY102090
I hear it more when I take a right hand turn but it can also be heard sometimes whewn turning left or just going straight at very low speeds.You can sometimes feel it in the sterring wheel.
Aug 29, 2010 at 6:24 AM
DOCFIXIT
  • 18,828 POSTS
Maybe u joint on intermideate shaft or rack see diagram
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_588.jpg
Also cradel mounts or stablizers
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_3_146.jpg
Aug 29, 2010 at 12:43 PM
