It's a 2002 Grand Caravan 3.3L FWD
There's an oil leak somewhere above which flows down to the oil pan and drips to the ground from there. There's also a drip from the passenger side at the same distance from the front end. So there will be 2 small spots on the ground every time. There are no leaks from valve cover gasket nor from the drain plug. There are no leaks visible from under the hood either. What could possibly the cause?
Sometimes I can smell oil burning coming from the air vent when the A/C is on
Aug 27, 2010 at 7:26 PM
