How to replace water pump
2002 DODGE CARAVAN
110,000 MILES • 6 CYL • AWD • AUTOMATIC
JEFFSAMMY
How do you replace a water pump for a 2002 Dodge Grand Caravan Sport AWD?
Thanks
Jan 26, 2009 at 4:03 PM
Here are the directions for all engine sizes:
Removal & Installation
2.4L Engine
Before servicing the vehicle, refer to the Precautions Section.
Drain the cooling system.
Remove or disconnect the following:
Negative battery cable
Right inner splash shield
Accessory drive belts
Right motor mount and bracket, support the engine from below before removing the mount
Front cover
Timing belt.
Timing belt idler pulley
Camshaft sprockets
Timing belt rear cover
Alternator and bracket
Water pump
To install:
Install or connect the following:
Water pump with a new O–ring gasket. Tighten the bolts to 105 inch lbs. (12 Nm). Rotate the pump by hand to make sure it moves freely.
Camshaft sprockets. Tighten the bolts to 75 ft. lbs. (101 Nm).
Timing belt idler pulley. Tighten the bolt to 45 ft. lbs. (61 Nm).
Timing belt
Front cover
Right motor mount
Fill the cooling system.
Start the engine and check for leaks.
3.0L Engine
Right motor mount
Front cover
Timing belt.
Water pump
To install:
Water pump. Tighten the bolts to 20 ft. lbs. (27 Nm).
Timing belt
Front cover
Right motor mount. Tighten the frame rail bolts to 50 ft. lbs. (68 Nm), the vertical fastener to 75 ft. lbs. (102 Nm) and the horizontal fastener to 111 ft. lbs. (150 Nm).
3.3L And 3.8L Engines
Remove or disconnect the following:NOTE
To remove the water pump it must be positioned between the pump housing and the drive hub. Refer to the accompanying illustration for further clarification.
Water pump pulley bolts
Water pump with the pulley loosely positioned between the hub and pump body
The water pump must be positioned between the pump housing and the drive hub so it can be removed—3.3L and 3.8L engines
To install:
New seal into the water pump housing groove
Water pump with the pulley loosely positioned between the hub and pump body. Tighten the bolts to 105 inch lbs. (12 Nm).
Water pump pulley and tighten the bolts to 250 inch lbs. (28 Nm). Rotate the pump by hand to make sure it moves freely.
If you need to review the steps, go to:
https://www.2carpros.com/articles/water-pump-replacement
I hope this helps. Let me know if you have other questions.
Jan 29, 2009 at 1:40 PM
Thanks for weighing in. Good info. Please let us know if you have any questions that we can help with. Thanks
Oct 10, 2019 at 3:46 PM
