2002 Dodge Caravan clicking noise
2002 DODGE CARAVAN
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBERT B
  • 4 POSTS
had a complete brake job done. New pads roters turned and now there is a clicking noise in the right rear wheel when brakes are applied.Mechanic is baffeled.Can anyone help? thanks.
Oct 23, 2009 at 8:16 AM
DOCFIXIT
  • 18,828 POSTS
Hi Check to see if auto adjuster is on correctly and tenision clip is installed.
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_200.jpg
Let me know Thanks for donate
Oct 23, 2009 at 9:40 AM
KHLOW2008
  • 41,814 POSTS
Further to what Docfixit has mentioned.
Inverted installation of the shoes springs would cause the hub to brush against them to emit clicking noise when brakes are applied.
Oct 23, 2009 at 9:53 AM
ROBERT B
  • 4 POSTS
The clicking noisie in rear brake 2002 caravan.Answers i got dont apply it has disc brakes on rear.
Oct 23, 2009 at 10:22 AM
DOCFIXIT
  • 18,828 POSTS
All Caravans have drum brakes only Grand or Town and country have disc what model ?
Oct 23, 2009 at 10:28 AM
ROBERT B
  • 4 POSTS
it is grand caravan sport sorry i didnt put in correct model.
Oct 23, 2009 at 10:35 AM
DOCFIXIT
  • 18,828 POSTS
Possible causes adapter abutments not lubed, left and right outboare pads different they are marked and damaged or worn guide pin bushings. Hope this helps
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_202.jpg
Oct 23, 2009 at 10:56 AM
ROBERT B
  • 4 POSTS
adapter abutments are lubed guide pin bushing fine outboard pads fine.possible roter?
Oct 23, 2009 at 1:44 PM
DOCFIXIT
  • 18,828 POSTS
Could check rotor for true but no pedal pulse on braking? Check torque on wheel lugs 100 ft.lbs.
Oct 23, 2009 at 2:20 PM
