Got the new motor in, works fine, but there seems to be quite a bit of slack in the cable. It does not pull and push properly causing the cable to get jammed up on the cable wheel. Is there a trick to get the cables back online? Thanks in advance for your time!
Jan 27, 2008 at 8:59 PM
