2001 Dodge Caravan window motor replacement
2001 DODGE CARAVAN
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
NICK123456
Got the new motor in, works fine, but there seems to be quite a bit of slack in the cable. It does not pull and push properly causing the cable to get jammed up on the cable wheel. Is there a trick to get the cables back online? Thanks in advance for your time!
Jan 27, 2008 at 8:59 PM
EVERCAMEN
  • 5 POSTS
I've replaced both of mine with no problem. Don't know if this will help, but the cables should criss cross like an X in the door. If yours is criss crossed, then I don't know.
Feb 1, 2008 at 9:02 PM
