Transmission problem
2001 Dodge Caravan Two Wheel Drive Automatic 101187 miles
The symptons are: When you turn key onand it does the little thing to check all dash lights. it gets to the point where it turns all the boxes around the P R N D etc. they should go out but all the boxes stay lite.
Rev and one of the FWD gears work but it does not shift up or down. The speedometer and odeometer do not move or change. Tach and all other gauge seem to work OK. the dealer I bought it from did a diagnostic scan. It returned something about the data link was bad to transmission.
Another mechanic said that the output speed sensor was the problem. Changed that NO HELP.
He suggested the input speed sensor next. Changed that NO DIFFERENCE.
I am at wits end here.
some thing to add: I noticed that the check engine light WAS NOT on when I test drove it after changing sensor I have a $15 donation from another unrelated elect problem. That turned out to be a weak 40A circiuit breaker just for info.
Apr 8, 2009 at 11:46 AM
