2001 Dodge Caravan steering won't turn right
2001 DODGE CARAVAN
SCURRAN0303
Steering problem
2001 Dodge Caravan Automatic
when the van is cold it won't turn right. you can turn it left but then it won't budge to the right. then after a couple minutes you feel it pop and it will turn then. it will pop when going from the left to right as soon as you chane direction with the wheel till it wwarms up good. then no poping and no problem till it sits and gets cold again.
Jan 10, 2010 at 2:37 PM
Have the rack and pinion checked for leaks. There are bushings in the rack. If they get worn, this can happen.
Jan 10, 2010 at 10:50 PM
