2001 Dodge Caravan Code P0201 on the computer
2001 DODGE CARAVAN
160,000 MILES • 6 CYL • FWD • AUTOMATIC
SILVERQUEEN2
what would make the #1 fuel injecter flood out injecter has already been changed and raw gas coming out the exhaust
Aug 7, 2009 at 10:17 PM
BMRFIXIT
  • 19,053 POSTS
check if injector pulsing or staying on at all times causing cylinder to flood
possible bag PCM
Aug 8, 2009 at 5:53 AM
SILVERQUEEN2
How do you tell if the PCM is bad. He has been working on this for 6 weeks He has changed everything that has anything to do with the fuel system. We can't afford to put much more into it. He is really good at fixing things but this really has him stumped
Aug 8, 2009 at 7:09 AM
BMRFIXIT
  • 19,053 POSTS
Use A noid light and check injector if pulsing or if light staying on
light on steady on one cylinder check wiring back to the PCM if all OK suspect bad PCM
Aug 8, 2009 at 7:51 PM
