2001 Dodge Caravan 2001 Chrysler Voyager fuel injector.....
2001 DODGE CARAVAN
56,000 MILES • 6 CYL • 2WD • AUTOMATIC
SILLAHAMERICA
I checked my 2001 Chrysler Voyager 3.3 L on the scanner the other day because of the miss in the engine. It says fuel injector cylinder 1. Then the next day, I checked it again. It says fuel injector cylinder 6. I checked the injectors on both cylinders. First, on cylinder 1, there is an open circuit. And on cylinder 6, it's closed. After 15 minutes later, I start the car again. I check both cylinders. On cylinder 6, it's open. And on cylinder 1, it's closed. I have no idea why it's acting up that way. If anybody has an idea, I would appreciate a response. My first post btw..... Thank you!
Sep 9, 2010 at 4:39 PM
Switch the two injectors with two other ones on the engine and see if the code changes to different cylenders or even with the different injectors in 1 and 6 the code comes back the same.
Let me know what you find.
Sep 10, 2010 at 1:21 PM
