2001 Dodge Caravan
2001 DODGE CARAVAN
ANGEL M GOMEZ
Engine Mechanical problem
2001 Dodge Caravan 6 cyl Front Wheel Drive Automatic
i got a 2001 dodge caravan 3.3 and my motor is bad so want to know if a 1994 dodge caravan 3.3 engine block will fit my van??
Nov 7, 2010 at 10:09 PM
We only recommend direct fit parts. When you change years, especially that many, you everything will need changed, injectors, sensors... THe problems arise when you have a sensor on the newer engine that didn't exist on the old one. As a resut, there is no way to hook it up, and it ends up causing problems.
Nov 8, 2010 at 7:30 AM
