2000 Dodge Caravan stalls when put in gear
2000 DODGE CARAVAN
SIERRA064
  • 4 POSTS
2000 Dodge Caravan 6 cyl Front Wheel Drive Automatic
2000 Dodge Caravan starts and runs fine put it in gear and it dies, had a trouble for an EGR valve put on a new EGR valve cleared the code and still same problem any ideas
Mar 15, 2010 at 6:01 PM
LEGITIMATE007
  • 5,121 POSTS
check the torque convertor clutch solenoid.
Mar 15, 2010 at 7:28 PM
LEGITIMATE007
  • 5,121 POSTS
Is there a check engine light on
Mar 15, 2010 at 7:29 PM
SIERRA064
  • 4 POSTS
[quote:82d1d3fcfb="legitimate007"]check the torque convertor clutch solenoid.[/quote:82d1d3fcfb] how would I check that I can not find that in my book and yes the Check Engine Light is on but I do not have a scanner but will go get one soon and find out what code has been set
Mar 16, 2010 at 3:42 PM
SIERRA064
  • 4 POSTS
[quote:71741e6cc4="legitimate007"]Is there a check engine light on[/quote:71741e6cc4] the light was on for the TPS but I had been testing that cleared the code now I have no codes but it still stalls when put in gear
Mar 16, 2010 at 7:26 PM
LEGITIMATE007
  • 5,121 POSTS
you can go ahead and clean the egr valve as this is a possibility, but I also need to know what size engine is your vehicle? 3.0,3.3,or 3.8. also the vehicle need to be scanned, it will make it sooo much easier.
Mar 17, 2010 at 7:13 AM
SIERRA064
  • 4 POSTS
[quote:ea18fa2a80="legitimate007"]you can go ahead and clean the egr valve as this is a possibility, but I also need to know what size engine is your vehicle? 3.0,3.3,or 3.8. also the vehicle need to be scanned, it will make it sooo much easier.[/quote:ea18fa2a80] I repaced the EGR valve and cleard all the codes but still have the problem that it stalls when I put it in gear, it dose sound like it maybe the torque convertor clutch solenoid but I dont know how to test it or where it is on the transmission. it has the 3.3L V6 with the G vin for the engine.
Mar 17, 2010 at 12:29 PM
LEGITIMATE007
  • 5,121 POSTS
well its coming up as transmission control solenoid and all it says is its located on the transmission, its a plug obviously, and there are three or four. it says this vehicle doesnt have a torque convertor clutch solenoid, they are control solenoids. it would really help if we could get this thing scanned again
Mar 17, 2010 at 12:56 PM
