Transmission problem
2000 Dodge Caravan 4 cyl Two Wheel Drive Automatic
My dodge caraven just starting doing this
grinding noise check brakes,axel brg. cv joints all ok then the noise stop but about 3 month later i had no foward gears (will not work in drive ) just Rev. change fluid check what ever i could still did nothing let it sit for a few days then i went to see what i could do started the van everything seem to work just fine foward and Rev. gears all ok now 1 month later i have no Rev. just foward gear. is it possible that some kind switch or valve,cable is going bad what can i check or is the transmission going bad.
Sep 6, 2010 at 11:25 AM
