2000 Dodge Caravan power outlets
2000 DODGE CARAVAN
90,000 MILES • 6 CYL • FWD • AUTOMATIC
LEEWFG
None of the power outlets work in my minivan. The owners manual shows no fuse for them. What should I check?
Jul 4, 2009 at 2:22 PM
JDL
  • 16,098 POSTS
Hello, my info shows the cigar lighter/accessory relay in the power distribution center, under the hood. The voltage to the coil side of relay is ignition feed, goes hot when you turn on the key. The voltage to the switch side of relay should be battery feed, hot all the time. Check fuse 4--20 amp in the power distribution center.
Jul 5, 2009 at 8:49 AM
