2000 Dodge Caravan Leaking around transmissioin solenoid
2000 DODGE CARAVAN
145,000 MILES • 6 CYL • FWD • AUTOMATIC
DROPPELMOTORS
My van had its first transmission leak around 34000 miles and the dealer replaced the transmission solenoid assembly and it seamed to fix the problem.
at 75000 miles it started to leak again from the same area. I replaced the solenoid pack gasket and it still continued to leak. I replaced it again recently and this time I used a small amount of silcone gasket sealant on both sides of the new gasket but it still continues to leak. Any suggestions?
Mar 13, 2009 at 4:06 PM
BMRFIXIT
  • 19,053 POSTS
NO silicone should be used at all in the solenoid gasket area
check clamps on the cooler hose above the solenoid pack
Mar 13, 2009 at 6:45 PM
